- English
- Arlo Forum Discussions
- Partner Integrations
- SmartThings integration failing (motion events)
Best answers
Mine started working yesterday. I had to unlink and relink the Arlo account to Smartthings. I also had to redo the smartlighting automations in Smartthings.
Thank you for providing your feedback, I have notified the Development team & we are working on a release for early next week. I will be sure to update you as soon as I hear more!
Thank you for your patience while we worked to resolve this issue. The issue with the Arlo SmartThings integration and not receiving alerts should now be resolved. You do not need to relink your devices, you should now be receiving your automation alerts.
This issue should now be resolved. If you have previously removed your Devices, please try adding them back to SmartThings and test again.
Thank you!
So you're saying I need to unlink Arlo/ST and destroy all of my automations that I have setup with my cameras, then re-link and re-create all the automations from scratch again? Trying to gauge the level of effort you're requiring end users to perform to "fix" your complete failure of an update that remained broken for a quarter of a year...
I deleted my integration, disarmed Arlo then relinked to ST. Getting motion alerts again. For how long fingers crossed.
You can add a virtual switch to all your camera related routines (on both the if and then parts). It doesn't matter what you do with the virtual switch in the routine, the main goal of doing it is to avoid ST deleting the routines when you unlink your Arlo cam. I am not sure when ST automatically deletes the routines but it could be one of the following (or both)
1.Empty IF
2.Empty Then
If you named your routines descriptively, it should be easier to slap back the right camera to the routines after you have re-linked Arlo vs redoing it from scratch.
Personally, I did this and plan to leave the virtual switch in the routines just in case I need to do a de-link and re-link in the future.
Hope this helps. Cheers!
Then: Delete the cameras in STs. I did also clear the Arlo app data and cache then deleted the app.
I reinstalled the app and then rebooted the base station via the app. I waited 10 minutes and then verified all cameras were connected and online.
Then I went to ST and integrated the Arlo app. It worked the first time and the only thing I had to do was go back to my automations and select the "Motion Devices" for my routines. The rules were still there, but no motion device was selected. It has been working for 2 days with no glitches. Prior to this process I had things semi working but it was sporadic at best. Hopefully this helps somebody.
Thanks, Arlo! This is very exciting news!
If we didn't remove or disable anything and were hoping for a magical fix that would just start sending motion events, do we need to do anything in particular for the fix to take place? I have an automation on smartthings to send me a notification whenever there is any motion event on any camera and still haven't seen any notifications for quite some time. Do I need to be restarting hubs or removing/re-adding cameras and re-building automations?
Wth. That's disheartening. I just relinked mine and recreated my automation. Arrrg.
Arlo camera motion is still not showing up in SmartThings from my Q+ and Pro 2's. I refuse to delete the SmartThings linked service since I can still control the On/Off of the Arlo cameras from SmartThings. Not to mention that other users here on this thread have already tried the Break/Fix option by removing the linked service without complete resolution since it appearently stops working after a while. So keep working on it.
@ShayneS Some users report that the problem has not been solved!
I’ve had a similar issue, but am not sure when it stated. (Being winter time here, I’m not outside at night a lot to notice.) I am using the ST Smart Lighting app so that when an Arlo Light or Arlo camera have motion triggered, then it turns on the Arlo light. (I have 6 lights and 4 cameras.) It’s worked without any issues for years now (except whenever Arlo updates something and breaks the connection between Arlo & ST). However, I’ve noticed that none of my Arlo lights turn on with any outside motion now.
I also use ST Smart Lighting to turn on certain inside “notification” light bulbs certain colors when a door or window is opened, or when there is motion inside and ST Home Monitor is in “Night” (or “Arm (stay)”) mode. That ST Smart Lighting operation still works just fine.
To troubleshoot, I created a quick Automation in ST, so that when motion is detected on “Arlo Light Front Porch”, then it should turn on “Arlo Light Front Porch”. This did not work.
I am able to turn the Arlo lights on & off directly from the ST App.
Is someone still working on this issue, or is the fix still rolling out?
1. Unlink Arlo from ST. 2. Disarm Arlo in Arlo App. 3. Relink Arlo to ST. 4. Recreate all your automations. 5. Rearm Arlo in Arlo app. 6. Cross your fingers that ST starts receiving motion alerts.
Mine did & stopped after 2 hours of said fix being released. Then a day later, last night started getting alerts. Since I gave up hoping this would be fixed and have created all my automations to work via Alexa I quit checking ST to be honest. Without a guarantee that it’s fixed 100% I’m not recreating my ST automations, as I have over 130 devices. It’s to much work on a hope it’s fixed. Like you I depended on Arlo integration that just worked for years.
Thanks for the info @ChadofCNC . I was hoping for a more definitive response from Arlo though, as I really don't want to go through the complete "uninstall & reinstall" of Arlo devices, automations, etc. in Smart Things, unless we know for sure that it will fix it. I've had this happen too many times where they tell me to clean slate everything, and it still doesn't work. Then another update/fix is pushed, (requiring another clean slate), and it still doesn't work. Rinse & repeat 3-4 times, and finally it's working again. I'd like to wait for the "final" fix if possible. Is there an Arlo rep who could confirm this is actually working for everyone now, once they completely uninstall and reinstall everything from scratch?
As a side note for the Arlo team: Why is it that whenever Arlo makes an update that breaks the connection between Arlo and ST, that we have to go into Arlo & reset the modes, then go into ST and remove all Arlo devices, unlink the integration and start installing everything from scratch (adding all Arlo devices back to automations, routines, smart apps, etc.). For a company that claims to "Work with SmartThings" (which was the main reason I went with Arlo over Ring) - it's been a pretty bad user experience. It works fine once it's all set up... until Arlo makes an update, and I have to start all over again. Imagine if that happened every time Windows did their monthly update - users would have all their user settings, configuration, browser favorites, etc. wiped out, and have to redo everything all over again...? I'm pretty sure we'd all be using a different OS pretty soon.
I have been seeing all the messages about it still not working, so I decided to see if I could get motion info from my cameras. I can not.
For me it's not a big deal as I am able to use the Alexa integration and that seems to be working well. I can use the Hubitat to ST integration to turn my cameras on and off and I use Alexa to get motion events to Hubitat. The motion events from ST however, are still not working.
@ShayneS - now 7 days after you claimed victory and left the thread, everyone is still reporting that nothing is fixed.
What's the status and timeline for actually fixing this vital integration that has been broken for a quarter of the last year?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
