- English
- Arlo Forum Discussions
- Partner Integrations
- SmartThings integration failing (motion events)
Best answers
Mine started working yesterday. I had to unlink and relink the Arlo account to Smartthings. I also had to redo the smartlighting automations in Smartthings.
Thank you for providing your feedback, I have notified the Development team & we are working on a release for early next week. I will be sure to update you as soon as I hear more!
Thank you for your patience while we worked to resolve this issue. The issue with the Arlo SmartThings integration and not receiving alerts should now be resolved. You do not need to relink your devices, you should now be receiving your automation alerts.
My system started working without any action on my part. Try adding a new simple 'test' automation.
About a week ago I had to de-link and re-link the Arlo account in Smartthings. After de-linking I deleted all of the automations in Smartthings and then deleted all of the Arlo cameras in Smartthings. Relinked the account and rebuild the automations. The latest fix a day or so ago...I didn't have to do anything. If you didn't delete the cameras in Smartthings after de-linking the Arlo account...I guessing the automation you set up maybe using one of the phantom cameras from the original link which won't work.
I’ve also deleted automations and redid them without effect.
No. You have to remove the Arlo integration from ST. Go to Menu -> Settings (gear icon) -> Linked Services -> 3 vert. dots, and select Delete. Click on the "-" next to Arlo. That will remove the integration.
Next, check to make sure all of your cameras are gone from the ST app. Delete any "phantom" cameras.
Hard-close the ST, and reopen it. Click the "+" sign to Add, click "Device". If you're lucky, you might be presented with an option to re-link Arlo, but Arlo should be an option in the list, even if you have to search for it.
I'm about to rip them all down and throw them in the trash. 🤬
@ATXScott wrote:
Yeah, apparently by re-linking my account to get SmartThings to work, my grandfathered free saving of recordings for my 3 old cameras stopped working. So now I have to pay for a subscription. Lovely.
Not convinced you are diagnosing that correctly.
Are you saying that paying for the subscription fixed the problem? Or are you just thinking that it would?
I logged into my.arlo.com and it immediately said I didn't have a subscription. That never happened before when I logged into that site. So I went ahead and paid for a subscription and now the app works, and all my saved videos are back. So, yes, paying for the subscription fixed the problem.
So I guess the question is why it said that - I don't think that the smartthings integration feature itself requires a subscription.
What cameras do you have?
Three Arlo Pro 4030s. Also an Arlo Floodlight. The Floodlight never allowed me to save/view my events without a subscription. But the Arlo Pro 4's have always worked without a subscription, until now.
The VMC4030 is the Pro, not the Pro 4. The VMC4030P is the Pro 2. Both have 7-day cloud storage w/o a subscription (the Pro 4 needs one for cloud storage, just like the floodlight).
Not sure if @JamesC can sort out why you got the subscription message all of a sudden. AFAICT you shouldn't have.
AppleTV
33 -
Samsung SmartThings
90 -
Security System
