- English
- Arlo Forum Discussions
- Partner Integrations
- Re: SmartThings integration failing (motion events...
Best answers
Mine started working yesterday. I had to unlink and relink the Arlo account to Smartthings. I also had to redo the smartlighting automations in Smartthings.
Thank you for providing your feedback, I have notified the Development team & we are working on a release for early next week. I will be sure to update you as soon as I hear more!
Thank you for your patience while we worked to resolve this issue. The issue with the Arlo SmartThings integration and not receiving alerts should now be resolved. You do not need to relink your devices, you should now be receiving your automation alerts.
Thank you for your understanding while we worked to identify & resolve this issue. This issue with the Arlo SmartThings integration not receiving alerts should now be resolved. Your automations should have automatically started again. If you are still experiencing an issue with your SmartThings automations, please Delink and Re-link your SmartThings account.
Regards,
Arlo Team
DAY 2 - STILL WORKING FLAWLESSLY
I did not have to do anything. Started working around mid-night yesterday, with no modifications needed. No disconnect or reconnect was needed, nor were new automations required.
After extensive testing, I have found the following…………
- Motion – Fixed. Arlo is now sending Motion messages to SmartThings. There is Motion History now in SmartThings, and triggering SmartThings Automations.
- Audio – Fixed. Arlo is now sending Audio messages to SmartThings. There is Audio History now in SmartThings, and triggering SmartThings Automations.
- Battery % – Fixed. Arlo is now sending the correct Battery Level messages to SmartThings.
- Camera Status – Still Broke. If you turn ON a Camera within the Arlo App, Arlo is not sending the flag to SmartThings to show that Camera is ON. Shows OFF in SmartThings. However, it is working the opposite direction, which was working before.
Thank You for fixing items 1 through 3. It was a long time waiting since December 23rd.
Rick (Retired Software Engineer/Tested)
Got the cameras to show motion with smartthings after I removed and re-linked. Smartthings will still not control cameras (turn off and on).
Mine stopped as well overnight... I would wager anything that they pushed out the hotfix last week to resolve, but didn't back port that hotfix into the next update they were working on. Then last night, they pushed a new update completely void of the emergency fix code. That would also mean they have little or no version control, which wouldn't shock me in the least, seeing how utterly incompetent Arlo is at doing their job.
The integration is down again for me as well.
Down for me as well. Looks like this fix lasted about 1 week. How can any company be this incompetent and why would anybody buy from them at this time?
Thanks for the update! I will have this investigated immediately.
with all due respect, how about having this FIXED immediately? And permanently, if it wouldn’t be too much trouble…?
Broke overnight for me as well. Worked last night. Sigh.
Motion detection started working again. Don't touch it now!!!
Mine was not working at 7:22 AM ET, but started working again between then and 7:49 AM ET.
Mine is working again. The real question is for how long this time.
We believe we have identified variables affecting the SmartThings integration. Thank you for your ongoing feedback and patience.
Regards,
Arlo Team
I have delinked and relinked my cameras with Smartthings, and I have rewritten my automation, but to no avail. Is this still an ongoing issue with everyone, or is there something else I need to do to get my motion automations working again from my Arlo cameras??
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
