- English
- Arlo Forum Discussions
- Partner Integrations
- Re: SmartThings integration failing (motion events...
Best answers
Mine started working yesterday. I had to unlink and relink the Arlo account to Smartthings. I also had to redo the smartlighting automations in Smartthings.
Thank you for providing your feedback, I have notified the Development team & we are working on a release for early next week. I will be sure to update you as soon as I hear more!
Thank you for your patience while we worked to resolve this issue. The issue with the Arlo SmartThings integration and not receiving alerts should now be resolved. You do not need to relink your devices, you should now be receiving your automation alerts.
The "fix" once you are able to reestablish the integration lasts only a few hours at the most. This integration used to be the most stable and worked perfectly right out of the box when I bit the bullet to buy Arlo.
I would like to confirm some things. I have 4 things I am missing status on that I know of:
1. No Motion detection
2. No Battery percentage indicating
3. No recorded clips in the timeline
4. No microphone use
Plenty of automations set up and working for years with SmartThings based off motion detected from my Arlo cams. All pretty much junk now…
Does anyone feel like Arlo is working on a fix to resolve this? Or should I start looking into an alternative camera system for my home that will send motion triggers to my SmartThings hub?
You would think they follow some change control process and can pretty much see what changes were made at the end of december that broke this. This shouldn't be such a mystery.
I’d be very curious to know why this wasn’t caught during QA…? Or was this even a test case? 😤
I agree! Such problems should be solved much faster! It's been 2 weeks! I switched some functions to Homekit.. everything works there (Arlo sends motion events to the Homekit), but all the automations I have is in ST
Apparently there were no test cases in QA for ST motion.
For functionality that is so widely used, someone most likely would have lost their job if that happened at my work place…
Especially if there was a chat forum filling up with issue posts from upset customers.
In most cases if it can't be solved past 24 to 48 hrs, you rollback the changes. Apparently they are trying to roll forward... This practice would never happen to a real SaaS provider.
My understanding is that there was a change on the Smartthings side of the house that broke the Arlo integration. With that said, it didn't break Ring or any other number of partner integrations from other companies. So why Arlo? A smartthings support response posted by another user said smartthings was trying to work with Arlo to get it restored... I'm a horrible human being, I know, so everytime I get a motion alert on my Arlo app, but it doesn't trigger an automation, I want to line people up in front of a firing squad.
You guys unveiled your own security system at CES, who could trust you? How many lives would be lost relying on your systems? Hyperbole... kind of... maybe... but jesus, get your act together Arlo.
Hi,
The Arlo Development team has identified the issue between Arlo and the SmartThings automations. A fix to resolve this issue will be coming soon. I will provide another update as soon as possible.
Thank you
Indeed. When I ordered my Arlo doorbell on Amazon the Smartthings app listed it as an available doorbell. By the time it arrived, Arlo was off the list.
What he just said! I have a bunch of security lights that no longer provide any security since they operate (or used to operate) off of motion detected on my Arlo cams…
I have (or had, at least) lights that turn certain colors, letting me know if someone is approaching my front or side doors. I can then pull up the camera and see who it is. I almost missed a delivery today since my lights no longer tell me when anyone is approaching. Please do let us know when this is fixed! Thx!
I am having the same issue with Arlo reporting motion alerts to SmartThings. Been happening almost a month now. Any one having any luck with support.. Their support is a joke as you can’t even put in a ticket unless you pay for a plan..
My biggest complaint was early on, someone reported that they wanted him to delete the app & reinstall the cameras. I don't know about the other users, but most of my cameras are mounted between 12-17 feet high! I'm not about to take them down, delete & reinstall the app, and re-pair the cameras, unless someone gives me a damn-good reason to do so! And I'm certainly not going to do it, just on the advice of a low-level tech!
(Multiple lines of frustration text redacted by user self control.)
Unpatiently waiting for this to be fixed. Maybe they can finally fix some of the other problems too with these cameras and apps but I highly doubt that.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
