- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Please send a token reset to my base station
Please send a token reset to my base station.
Hi cmmorrow620, PaulyP, rob9876, kebian, Norstar, cbh32890, arlo_user_85, ARbbbbbb, Pmramos, tdiggity, and mykelbw,
I've sent a token reset request to your Base Station(s)/SmartHub(s) that should resolve the issue. Please reboot your Base Station(s)/SmartHub(s) (remove and reapply power) and allow the Base Station(s)/SmartHub(s) to come back online. Then make sure that you have the latest version of the Arlo iOS app and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
I am unable to get my new smarthub to connect to HomeKit. I am not familiar with the concept of a token. Can someone help me?
Hi,
I have an arlo basestation that does not show up in Homekit. Please send a reset token? I can give you more information if required.
If you need to know which one in order to send the token, it’s the one with the serial ending 3B.
Jessica: it seems that I also need a token reset to allow my new smart hub to connect to HomeKit. Can you also send me one? Please.
Hi, could you please send Homekit reset token to my base station? Thank you!
Hello,
I think I need a token reset as well. I've had this issue for a while now and I've tried updating the app and restarting the base station.
Thanks,
Caleb
Hello,
Would it be possible to get a Token Reset for my Base Station so that i am able to setup Apple Homekit please?
Arlo app stuck on “Discovering your device”.
Hi Jessica,
I am having the same issues again, I successfully connected the first time, however I had to reset all my cameras as the power transformer for my hub stopped working. Now it just shows the Discovering your device message.
Can you send me a reset token as well please?
Highly appreciate it.
Regards
The Arlo application doesn't recognize my basestation when trying to add to HomeKit. Please assist.
Excellent JessicaP.
That worked perfectly!
I am up and running.
Thanks !!
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
