Hi,
since updating to ios16 i can’t connect to homekit anymore… could a token reset help? If so please send one to my station.
tx!
MK_Flight,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
I am having the same issue. I can’t connect my Arlo Baby monitor or my base station. What is a reset token?
farmaj86,
Arlo Baby cams do not connect to base stations, they connect directly to your home network. Are you just trying to set up the baby camera or are you also trying to integrate with Apple HomeKit?
I’m trying to set up (separately) the Arlo Baby and my base station for my 2x Arlo Pro 2 cameras. However, aince the iOS 16 update, neither connects to HomeKit
farmaj86,
Hi, can i have a token request to?
because nothing helps to get a connection to my cameras with homekit.
tx
Edit: i did not restart my home station… will try this first 🙈
edit2: restart made my station visible in homekit! Tx!
AppleTV
31 -
Samsung SmartThings
81 -
Security System
