  • 1 Reply
  • 2037 Views
  • 1 In Conversation
Sooner2k18
I have 3 base stations on my account.  2 work correctly with Homekit, but attempting to re-add the base station ending in SN#C50 doesn't work.  The base station works correctly, the cameras work correctly, and everything is on the same WIFI network.  I would like to have a "Token Reset" done on the base station ending in "C50" or "Garage Arlo Basestation" on my account.
I've contacted customer support and they seem to have no idea what a token reset is and keep running through the same troubleshooting steps over and over.  I've asked to be escalated to technical support or someone that can reset my token and they are either refusing or don't know who to direct me to.
Am I crazy, or should technical support know how to perform the step that seems to happen via forum response from Arlo support?
Sooner2k18
I was able to get escalated to the appropriate support level and they got my token reset and it resolved the issue.  This ticket can be closed.
Sooner2k18
