- English
- Arlo Forum Discussions
- Partner Integrations
- Working solution to Arlo Ultra Hub HomeKit set up....
Working solution to Arlo Ultra Hub HomeKit set up. No code was supplied.
Anyone managed to find a guaranteed way to make the Ultra camera system work with Home kit. The instructions are useless as no Code was supplied with the Kit nor will the instructions on the website work, the phone sits looking and never finds anything… tried setting it up using both Arlo app and HomeKit app with the same results…
Hi Davv,
What error are you seeing when trying to set up your Arlo system to Apple HomeKit? You can refer here to learn how to set up Apple HomeKit without a code: How do I connect my Arlo camera to Apple HomeKit?
I've sent a token reset request to your base station to see if that resolves your issue. Please reboot your base station (remove and reapply power) allow the base station to come back online. Then make sure that you have the latest version of the Arlo iOS app and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Hey Davv,
The link above explains how to set it up without a setup code.
For further assistance regarding this, I would suggest for you to navigate to Settings > Support in the Arlo iOS or Android app for service options available to you.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
