- English
- Arlo Forum Discussions
- Partner Integrations
- Re: IFTTT “There was a problem processing the requ...
A couple months ago, I had IFTTT set up to arm/disarm my Arlo system via my Google Home device.
It worked perfectly..
But, I haven’t used it for a couple months and wanted to re-enable it all.
Today when I’m setting it up, every time I get a notification that “There was a problem processing the request”.
I’ve tried uninstalling and reinstalling the IFTTT app.
I’ve tried setting it up using IFTTT on another device.
I’ve tried unlinking & relinking my IFTTT account to Arlo.
I’ve tried creating a new IFTTT account.
No matter what I try, it won’t work.
How do I fix this?
Same issue for me. It says "Arlo seems to be down right now".
I gave a try to "Stringify", instead of IFTTT, and it works fine.
As IFTTT seems to be "not supported anymore" by ARLO, let's use something "usable" ...
Been like this the whole two months I've had my Arlo's... You can use IFTTT and Arlo as a trigger, say my Arlo detects motion, then turn on a light (if you have other smart devices), but not as an action to say, arm, or disarm, or record Arlo... Stringify works though.
Having the same exact issue just today...
AppleTV
21 -
Samsung SmartThings
59 -
Security System
