Hello
I successfully added my smart hub to homekit once, but I had to re-do the homekit setup. Now I am stuck at the "Devices found" stage of the hub's homekit section. Reading around the community pages it seems like I need to get a token reset to be able to re-add the hub to homekit. Can you please push one to the hub associated with this account?
I also need a token reset please.
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
I also need a token reset please. Thank you
arlo basestation - VMB4540
serial A7311478A0634
My arlo apple homekit integration broke last seek for some reason. Can I get a hub token reset associated with my account please? Thanks!
Hello can I get the token reset associated with my account [email protected]?
@arlohelpmepleas I am not seeing an account for you. Can you DM me the email address associated with the account?
@Tanraell and @Rom101 I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
Hi, I have the same problem. Can you send me token reset? Arlo devices don’t work anymore with HomeKit app…
It worked, thanks. I don’t understand why it was down…
I will throw my hat in the ring, I just recieved a replacement hub for the one that refused to connect to HomeKit, and the replacement also will not connect. I'm hoping you can send a token reset to the unit, I have 2 and the one that needs the token reset is the one with serial ending in 4675.
please add me for a token reset
i still do not have a selection for homekit
do I have to have a subscription to get a Homekit connection
I reset the base and added the cameras. Can you please sent a token reset request to my base station ?
I need to integrate Arlo with homekit.
Thank you.
Hardware VMB5000r6
Serial Number A6G21875A018A
did not work, I even reset the base station. will try another day
thx anyway
@MESUT73 I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
Problem is solved. Thank you!
BR
I added a second hub and 3 cameras and I am stuck in the same looking for devices. Can I get a HomeKit Token reset
Hi there, I require a HomeKit Token reset for my two Arlo hubs.
Hi
AppleTV
33 -
Samsung SmartThings
89 -
Security System
