zmit
Hello
I successfully added my smart hub to homekit once, but I had to re-do the homekit setup. Now I am stuck at the "Devices found" stage of the hub's homekit section. Reading around the community pages it seems like I need to get a token reset to be able to re-add the hub to homekit. Can you please push one to the hub associated with this account?
161 REPLIES 161
Restalaan
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
arlohelpmepleas
I also need a token reset please. Thank you
arlo basestation - VMB4540
serial A7311478A0634
Tanraell
My arlo apple homekit integration broke last seek for some reason.  Can I get a hub token reset associated with my account please? Thanks!
Rom101
Hello can I get the token reset associated with my account [email protected]
BrookeN
@arlohelpmepleas  I am not seeing an account for you. Can you DM me the email address associated with the account?
@Tanraell and @Rom101 I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
dcollas
Hi, I have the same problem. Can you send me token reset? Arlo devices don’t work anymore with HomeKit app…
BrookeN
dcollas
It worked, thanks. I don’t understand why it was down…
HossBud
I will throw my hat in the ring, I just recieved a replacement hub for the one that refused to connect to HomeKit, and the replacement also will not connect.  I'm hoping you can send a token reset to the unit,  I have 2 and the one that needs the token reset is the one with serial ending in 4675.
BrookeN
wkobayway
please add me for a token reset
BrookeN
wkobayway
i still do not have a selection for homekit
wkobayway
do I have to have a subscription to get a Homekit connection
BrookeN
MESUT73
I reset the base and added the cameras. Can you please sent a token reset request to my base station ?
I need to integrate Arlo with homekit.
Thank you.
Hardware  VMB5000r6
Serial Number  A6G21875A018A
wkobayway
did not work, I even reset the base station. will try another day
thx anyway
BrookeN
@MESUT73 I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
MESUT73
Problem is solved. Thank you!
BR
Bcdalsoglio
I added a second hub and 3 cameras and I am stuck in the same looking for devices.  Can I get a HomeKit Token reset
BrookeN
PeterKosta
BrookeN
Perry1987
Hi
