Hello
I successfully added my smart hub to homekit once, but I had to re-do the homekit setup. Now I am stuck at the "Devices found" stage of the hub's homekit section. Reading around the community pages it seems like I need to get a token reset to be able to re-add the hub to homekit. Can you please push one to the hub associated with this account?
I apologize for the delay in my response. I have reset the token again. Do a full reset of the Base station and then reset up the HomeKit. You can add the cameras before or after, it should work either way.
Thanks the base is connected to HomeKit but it took several resets until I moved the base closer to my router ( it was near one of my satellites). It connected immediately after moving. Thanks for your help
Regardless of all my efforts to connect Arlo base to Homekit, I failed every time. Can you please reset the token?
Hardware VMB5000r6
Serial Number A6G21875A018A
@MESUT73 I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
First of all, thank you very much for the support.
After the rebooting as the way that you described, I tried both from Homekit and Arlo app to setting homekit. But both of tries were unsuccessful. Trying from Homekit gave me “unable to add accessory. This accessory cannot be used with Homekit” error message. Trying with Ao app, after entering the code, it stuck with “connecting” message for several minutes and no further progress. Then I exit setup.
Can you please tell me what else I can do to complete HomeKit setup?
thank you in advance for your help.
You will need to do a reset of the base station and re-add the cameras. I will reset the token again, try to set it up after the full reset.
https://kb.arlo.com/1057976/How-can-I-factory-reset-my-Arlo-SmartHub-or-Base-Station
Please reset my HomeKit on my arlo base station.
i called today they said they reset it but it’s still not working
don’t worry it’s working now
Hello, can I also request a token reset be sent to my hub?
thanks,
Thank you
I am unable to add my basestation to HomeKit. Can you please reset the token?
I need a token reset on my VMB4000 in order to establish connection with Apple Homekit - can you help please?
Can a token reset be sent to me please.
@rs5206 and @dsimpson I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Hello Team,
I am having this exact issue. How can I get a token reset to my Hub?
It didn’t work for me. I’ll have to reset the whole system
Hi,
I had to change my router and have to set up HomeKit, can you please help me resetting my homebase so I can set it up again?
Regards,
Can I get a token reset too please. To the hub associated with this email.
@ShirlG , @Dester68 and @cmscmadd I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
@dsimpson I have reset the token again. Before you reboot the basestation/hub, uninstall and reinstall the app first. And then follow the instructions in the link for setting up the Homekit without a code.
Thank you so much. It worked that time.
I uninstalled the app and reset the hub but it is still not working. Can you please try another token or is there something else I can do to get my Arlo equipment setup with HomeKit
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
AppleTV
33 -
Samsung SmartThings
86 -
Security System
