Homekit not able to add BaseStation
  • 15 Replies
  • 6012 Views
  • 6 In Conversation
Ralph2022
Same issue as the others - if I try adding the arlo to HomeKit, it gets stuck discovering.  Please send a reset token.  Thank you! Serial A6G2187HA05D0
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
15 REPLIES 15
Ralph2022
Thank you! Works well now.
Mikko76
Hello,
I`m not able to add Arlo Base Station to Apple Homekit, model VMB500
serial number A6G21871A005F
Mikko76,
Mikko76
Thank you, it`s working now 🙂
tex73
Hi Arlo support,
I have the same problem as others here.
I can't connect my Arlo Pro Base Station to HomeKit via the Arlo Secure app.
The setup screen says "Discovering your device. Please wait." but never finds my device.
Can you please reset my token?
Arlo Pro Base Station : Harware VMB4000r3 , SN 4R026B7AA22B3
Thanks!
tex73,
Blablah12345
I am unable to add my upstairs base station Ultra SmartHub VMB5000 to Apple HomeKit.
Blablah12345,
Blablah12345
Thank you!
But now the cameras connected to my downstairs base station (VMB5000r6) are not responding in the Apple Home Kit app (works fine in the Arlo app). I tried removing and re-adding the base station to Apple Home Kit and it cannot be found (both through Arlo and Apple HK app). I tried restarting the base station too. Any ideas
Blablah12345,
What is the s/n for that base?
Blablah12345
Downstairs S/n - A6C32572A0579
Upstairs S/n -
A6C31A7HA0519
(upstairs is working but just in case you need to reset it and I need to delete and add again)
Blablah12345,
I've reset the token for device ending in 0579. You should be able to set up using the same instructions linked above.
Waymo
Im having the same issue trying to connect to Homekit. Can you please send a reset token:
SN: A6F31A7TA0FB2
Waymo
I contacted supported and this has now been fixed
