https://kb.arlo.com/000062279/How-do-I-connect-my-Arlo-camera-to-Apple-HomeKit
Thanks for doing that. I’m still unable to connect to Apple Home and I don’t see the options laid out on the forum to link to Apple home without the HomeKit code. Is there something that I am missing ?
Were you able to get this far? Tap Settings > My Devices.Select an Arlo base station.Tap HomeKit. What happened after you tried this method?
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Could I also get this magical reset token? My cameras had integrated into my Homekit well and were working for a few weeks when they all of the sudden weren't responsive in homekit but were fine in Arlo app. Can't get either one to re-recognize the base station. I would really like to continue using the automations I had set up to work with my cameras...
VMB4000r3
VMB4000r3
@ShayneS that seems to have worked!! Thanks
I seem to be having the same problem that others have had with this in that I can access all my Arlo devices via the Arlo app, but Homekit doesn't appear in the app under the VMB4000(r3) device menu. I have reset the base station, and connected my phone to the wireless network being broadcast by the router that the base station is connected to.
I'm also not able to see a HomeKit option in the base station settings. I'm using a VMB4500r2 with firmware level 1.16.5.6 and Arlo app version 3.1
Hi, still don't see HomeKit option. I tried restarting, as well as removing and adding the base unit (and all the attached devices).
Did you perform a factory reset on your SmartHub?
I just reset your token again, please try and look for the HomeKit option under Settings > My Devices.
I’m still unable to see HomeKit in the base station config. Any other suggestions?
Hi @IanPB
Can you remove > Re-install your app to the latest version of the Arlo mobile app v3.2 > Reboot your phone then tar again?
I did not do a factory reset, but I did reinstall the Arlo app on my iPhone and can now see HomeKit Setup in settings. When I went into HomeKit Setup in Arlo the first time, it discovered the VMB4500 and was able to creat a new HomeKit room. But it wouldn't add the VMB4500 to the room. I did not have an Apple "home hub" configured, so I added an Apple TV. Now when I go into HomeKit setup in the Arlo app, it gets stuck at "Discovering you device. Please wait."
I see, thanks for the detailed info. Please contact the Support Team to further investigate this issue with your device & HomeKit. You will find several options for contacting support in the provided link.
Hi Shayne,
Can you send a reset to my base station as well please. My homekit integration stopped working.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
