Hello,
I'm trying to enable HomeKit and have no code underthe base. According to all the other messages here, I need a token reset. Can somebody help with that please?
Former NETGEAR Employee.
Disclaimer: Views and opinions expressed here are my own.
JamesC, may I please have a token reset as well? I had requested one last week, but never received a response.
What is the serial number associated with your base station? The account you're using on the community has no Arlo account associated with it.
JamesC,
Below is the information for my base station:
Hardware: VMB4000r3
SN: 4R03737UA8580
The account it is associated with is
longhorn3679,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Hello,
I'm trying to enable HomeKit, stuck on looking for devices. According to all the other messages here, I need a token reset. Can somebody help with that please?
Nelnorno,
Phip,
Hello,
I would like to request a token reset for the Smart Hub connected to this account. I have the VMB4540r2.
thank you so much!
I need a token reset. What do you need from me?
Token reset on:
VMB4540r3
I am in desperate need of a token reset for my system.
Request token reset
irondf, Dinho1993, Jtbillups, Ultra)user1
Can I get a token reset for my HomeKit?
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
Hello, can you please send me a token reset also - I accidentally deleted my Home and when trying to setup HomeKit again the App is stuck on 'discovering your devices'. Based station is VMB4000r3, S/N 4RD3817JA1FFB. Alll firmware is up to date.
Thank you - that worked, all sorted now. Thanks for the prompt response!!
Hello I need a token reset request sent to my base station please.
Hello can you send me a reset token as well please. Thank you.
Hi,
Please may I also request a token reset
a
Thank you
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
