Hello,
I'm trying to enable HomeKit and have no code underthe base. According to all the other messages here, I need a token reset. Can somebody help with that please?
Former NETGEAR Employee.
Disclaimer: Views and opinions expressed here are my own.
All working fine now after restarting my router
Can I get a token reset too please.
Hi!
Can my hub get a token to?
Hi I'd like a token reset for my HomeKit, thank you!
Hello I need a token reset as well. Removed from homekit a while ago and just got some new cameras. Need to add y base station back. Thanks!
cmscmadd, Ksunding, GGArlosystem, snoopydoggy1741
I've sent a token reset request to your Base Station that should resolve the issue. Please reboot your Base Station (remove and reapply power) and allow the Base Station to come back online. Then make sure that you have the latest version of the Arlo iOS app and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Hi, I had to replace my router and need a Token reset so I can get my Base Station in HomeKit again. Can you please help me get it? I asked in another thread already, but no response so far.
Thanks,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Thanks, it worked.
Hello
Trust you are well
Could I also please get a token reset on A0E2067VA0905?
Thank you
warm regards
I need a token reset had it all connected and now it’s gone
Hello,
can I also have a Token reset for my base, I’m not able to setup my cameras on homekit.
VMB4500r2
5TM19A7FA1141
thank you
Hello,
I am also requesting an Apple home token reset on my base station.
thank you.
I think I need to reset token
can you help?
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
Hello @BrookeN
I just turned off and disconnected the power from my base and attempted to add to home using the instructions and I’m running into the same issue. It is just stuck on the “discovering devices” screen.
It has been reset. Please follow the steps within the link above.
I have reset and discovered nothing used to work with HomeKit and then it vanished please reset token
Joepepperz,
Hello JamesC! I would also like to request a token reset please 🙏
Steve24,
Can I please request a token reset as well?
Hardware: VMB4000r3
SN: 4R03737UA8580
I am having rhe same issue with home kit, can you please reset my security token
I am having the same issue with my homekit integration that was working at one time, can I get the token reset pease?
Abe777, taw1
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
