HomeKit Token Reset
  • 16 Replies
  • 6163 Views
  • 5 In Conversation
itscobra
Hi!
Need HomeKit token refreshed for my SmartHub VMB4540. Thanks!
16 REPLIES 16
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
If you see library:
How do I connect my Arlo device to Apple HomeKit?
If you see feed:
https://kb.arlo.com/000063184
itscobra
Good Morning,
Seems as if I still am unable to add to HomeKit thru the Arlo Secure app. Still requiring a QR-code or PIN-code.
BrookeN
Did you use the instructions to set up without a code.
itscobra
Yes. It still did not work.
BrookeN
You are following these steps correct?
To setup an Arlo device without a setup code:
  1. Launch the Arlo Secure App on your Apple device.
  2. Tap Settings > My Devices.
  3. Select an Arlo SmartHub or Arlo Base Station.
  4. Tap HomeKit.
  5. Select the Arlo SmartHub or Arlo Base Station you want to add to Apple Home.
    If you receive an Uncertified Accessory Error message, visit: When adding my Arlo Base Station to Apple Home, what should I do if I receive an Uncertified Accesso...
  6. Select a Home or tap Add New Home.
    If you don’t have a Home set up in the Arlo Secure App, you are directed to create a Home.
  7. Select a Room or tap Add a New Room.
    If you don’t have a Room set up in the Arlo Secure App, you are directed to create a Room.
  8. Tap Continue to add devices to HomeKit to add devices or additional Base Stations.
  9. Continue through the setup flows to confirm the name and room placement for each device.
    Note: The name that you give each device is used for Siri commands. Choose a unique name that is easy to remember and pronounce.
  10. Confirm the name of the device.
  11. Tap Skip, or rename any other devices as needed.
  12. Tap Finish.
    Your devices are ready to use with Apple Home.
itscobra
I am able to get to step 7, but then I am showed the attached images. I can only proceed by adding the HomeKit QR code or PIN code, of which my SmartHub does not have.
BrookeN
You do not need to scan the QR code. Please follow the steps listed above.
itscobra
Go ahead and let me know what steps I’m not following.
irm215
BrookeN
I apologize for the delay in my response I was out of office. Were you able to get the homekit to work correctly?
itscobra
Nope. Still not working.
BrookeN
Then you will need to do a reset of the basestation. Please keep in mind that all the cameras will have to be added back on after doing the reset. If you are wanting to do that please let me know and I will reset the token again, as soon as the reset has been done.
pedro_
May I request a HomeKit token reset? VMB4540r3 s/n A7422176A012D
ShayneS
@pedro_
Thank you
pedro_
Hi ShayneS, no luck I'm afraid after power-cycling my base station and added the camera from scratch. May I request another reset?
BrookeN
@irm215 I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
@pedro_ I sent the token reset again. Please follow previous steps.
