HomeKit
  • 6 Replies
  • 2773 Views
Ctaffe94
can’t link my HomeKit to my Arlo base. It’s asking for a HomeKit code, which I don’t have !
6 REPLIES 6
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
If you see feed:
https://kb.arlo.com/000063184
There is a spot that states to setup without a code, please follow those steps.
Ctaffe94
I followed the directions and it’s still giving me the same issue
Ctaffe94
It  still won’t add asking for a code
BrookeN
You are more then likely going to have to reset the basestation. Please keep in mind if you reset the basestation, you will need to add the cameras back on. If that is something you want to do let me know as I will need to reset that token again.
Ctaffe94
Yes
BrookeN
@Ctaffe94 It has been reset.
