HomeKit Token Reset
Greetings,
I have tried to attach my VMB5000 to HomeKit but it is asking for a HomeKit code. My device does not have a sticker for this. Does this require a reset of the token and how would I get one?
Thanks!
I have tried to reattach my
VMB4000r3
Callachd,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Can I get a token reset please to get my Homekit working. Thank you.
keithwebb,
VMB4000r3
please can you reset the token
thanks
Please can you reset my HomeKit token
thanks
David
Callachd,
Hi,
I can't get my new VMB5000r6 into HomeKit as well. Please do that token reset for me, too.
chris
I am so disappointed. I had a call with arlo support for an hour today - no solution found. They said, they did that „token reset“, but I don’t believe that.
I still can’t connect my new 500+€ arlos to HomeKit.
Please help.
thank you.
Mike2278
Brotherlui,
Is your base station online? It must be online to receive the token reset.
My base station is once again not working with HomeKit. Please send a new token.
JM08,
Could you please send me a token reset again? Still not seeing the Homekit button in the app.
@JamesC is there any way to receive this code through email?
After last reset still not working.
Flaff,
I need this reset token as well
Winston17,
Dear @JamesC ,
It is still asking for the Homekit code but it's not appearing, is it possible to have the code through by email or private?
Thank you
I have the base station VMB4000r3. I have been sent a token. I have power cycled my base station. I am still unable to connect this to Apple Home kit.
1) If I go through the Arlo app it does not have an Apple HomeKit option.
2) If I go through Apple HomeKit it asks for a code or to scan a QR code. There is no code or QR code on my model base station.
Please advise me on how to fix this so my cameras work with Apple HomeKit like they should. Thanks.
Basis Station funktioniert, mit wird aber in der Alrlo App HomeKit gar nicht angezeigt. Wenn ich bei HomeKit ein neues Gerät eingeben möchte, findet er die Basisstation aber möchte einen Konfigurationscode haben. Diesen habe ich gar nicht
hi, please could you reset my token.
thanks
David
Hi James
please could you reset my HomeKit token
thanks
david
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
