Hello
I have an older Arlo 2 Pro with no HomeKit pairing code listed on the base station. Sounds like a token reset would give me one. Is that true?
If not, how would I obtain a code?
thanks,
Vince
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions
:How do I connect my Arlo device to Apple HomeKit?
Unfortunately that did not resolve my issue. When I’m going through the HomeKit workflow through the Arlo app, it is still requiring a code for the hub.
Did you follow the steps to set up without a code? Try logging out of the account and logging back in. And then following the steps provided to set up without a code.
I am also having trouble connecting my base station (VMB4500r2) to HomeKit. Could someone help to request a token reset for me? Thanks!
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
Hi, can you kindly send a new token for apple homekit.
AppleTV
31 -
Samsung SmartThings
82 -
Security System
