- English
- Arlo Forum Discussions
- Partner Integrations
- Re: HELP! vmb3500 setup with T-mobile Home Intern...
Hi. I have a new Arlo setup with four cameras and the VMB3500 base station. I cannot get the base to connect to the Arlo Secure app either through the iPhone or through the Internet. I am using T-Mobile Home internet and a speed test is telling me that I am connected at high speeds, but Arlo support is telling me it is the network. Has anyone else overcome this issue?
FWIW, I checked out the T-Mobile network a while back, and successfully connected a VMB5000 to it. But this was not a new setup, all I did was move the VMB5000 from my normal router to the T-Mobile gateway.
The iPhone does need to be connected to the gateway Wifi, and if you use a VPN on the phone it needs to be disabled.
Did you try installing it from a PC (my.arlo.com)? That sometimes will work when the app fails.
Also, look at the attached devices list on the router, and see if the VMB3500 shows up on that list.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
