- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Doorbell my mobile phone and Google nest hub m...
When someone presses the doorbell button, I don't get any automatic live stream showing the video of the person who is at the door on either my phone (pixel 6) or Google nest devices (I get video when I accept the ring by Pressing the green button) Is there any solution for this? I want my nest hub to show me a live stream when my doorbell is pressed and was wondering probably there is a solution for this
Kamrant,
Google integration does not currently support automatic streaming on doorbell presses. For more information on this integration, take a look here: How do I connect my Arlo cameras to Google Home or Google Assistant?
Thanks James, how about the actual Arlo app on my phone? I should be able to get a live stream on my phone when someone presses the doorbell right? it comes up as grey until I accept the call. any configuration I can get this to work?
Kamrant,
You can live stream manually within the app or accept the call when the doorbell is pressed. When the doorbell is pressed, to see the stream you must accept the call, there is no way to make it automatic.
AppleTV
32 -
Samsung SmartThings
84 -
Security System
