Connecting VBM5000r6 to HomeKit
  • 4 Replies
  • 2855 Views
Kevin30376
I just bought and installed two ultra 2 cameras with the VBM5000r6 Basestation, however, I can not get the basestation to connect to my HomeKit.  The error message I get is "Unable to Add Accessory. This accessory cannot be used with HomeKit.  Is there anything I can do to get this up and running? It is very frustrating.
You need a token reset from Arlo Once that happens, you restart the smarthub. Then you can add it to homekit.
The mods ( @JamesC or @ShayneS ) can do that for you (and will reply on this thread).  Or you can contact support.
ShayneS
Thank you
Kevin30376
Well, it worked. Thank you.
ShayneS
No problem : )
