- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Cannot connect Arlo Baby to HomeKit since upgr...
I have upgraded to the new app (this was a nightmare as I had to completely reset the device in the legacy app first as it wasn’t showing up on the new app) and now I can’t add Arlo into my Apple HomeKit. The sole reason I bought it over other brands. When in the app I select the HomeKit setup option and it just sits on ‘discovering device. Please wait’ I know it’s not an issue with Apple as it was working flawlessly in HomeKit moments before upgrading. So what do we need to do to get back what we had in the legacy app?
I have tried to connect the device via the QR code within the the HomeKit app (a way that worked flawlessly in the past) but wouldn’t work. Tried manually entering the code and scanning less than a meter from both device and router. Found nothing. Once again was fine before the new app. Currently device is not fit for purpose.
yeah same here. might try open a support case, not that ive ever had luck with that before
Hi. Did you able to solve this issue? I’ve tried many things but the base station does not show up at all.
Thanks,
Semih
Hi Akansemih,
Are you having problems with your Arlo Baby not connecting to HomeKit? Or are you referring to your Arlo Base Station? What error message or problem are you experiencing?
						Amazon Alexa111
						Apple HomeKit713
						Apple TV App7
						AppleTV31
						Arlo Mobile App60
						Arlo Pro2
						Arlo Pro 21
						Arlo Q (Plus)1
						Arlo Secure10
						Arlo Smart39
						Arlo Wire-Free1
						Before You Buy30
						Features86
						Firmware Release Notes8
						Google Assistant94
						IFTTT92
						IFTTT (If This Then That)117
						Installation90
						Modes and Rules13
						Motion Detection1
						Online and Mobile Apps70
						Samsung SmartThings82
						Security System1
						Service and Storage5
						SmartThings73
						Troubleshooting393
						Videos1
