- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Can I please get a Homekit token reset?
Can I please get a Homekit token reset? I have moved home and I had to start HK from scratch,
Thank you
Can you please reset my token as well?
Vikki55,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
I’m having the same issue. I click Setup HomeKit and it just spins on discovering.
Nsutton,
It was working great until this weekend and doesn't connect to Homekit anymore. Can you send another token reset?
Nsutton,
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
