Token reset
  • 25 Replies
  • 12161 Views
  • 11 In Conversation
Guyincog
Hi there, could I please get a token reset on my hub? Having a problem integrating it with HomeKit and the token reset fixed the issue last time.
Thank you!
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
25 REPLIES 25
Guyincog
It worked. Thank you!
Wallndan
Hello
Can you please sent a token to my basestation once again?
i do not understand why this is needed
// Daniel
Wallndan,
Retired_Member
Not applicable
Hi - my Arlo cameras are no longer responding in HomeKit.  Can I please get a token reset sent to my base station?  Thanks!
JG222,
Sandiegoglasguy
Also need a token reset please. Thanks
Sandiegoglasguy,
Mul51
Hi
would it be possible to get a token reset to allow me to use HomeKit which has stopped working. This fixed it last time this happened.
my basestation is a vmb4000r3.
thanks
peter
Mul51,
chlee
I'm having same problem. Can you send token reset  to my basestaion for homkit.
chlee,
Samarth
Hi there,
I also need a reset token . I am unable to add my VMB4000r3 on HomeKit.
appreciate the help.
Samarth
Hi @JamesC ! Could you assist me with the reset pls? Appreciate your help in sorting this!
im also unable to add my base station and cameras to HomeKit.
Regards,
samarth.
Samarth,
Revilgaz
Hi, @JamesC I too am unable to connect to HomeKit and was wondering if I could get a token reset as well, thanks!
Revilgaz,
Revilgaz
Works perfect now, thank you!
asmonitoring
asmonitoring
cc: @JamesC
asmonitoring,
Samarth
Thanks for this @JamesC however when I try to add it to my HomeKit, there’s no code available on the box. How are we to add this? Earlier it would be found and then added. Now it asks for a code.
appreciate your help.
chemguy1973
Same issue for me on base station 2. Can I get a token reset?
chemguy1973,
