Hi there, could I please get a token reset on my hub? Having a problem integrating it with HomeKit and the token reset fixed the issue last time.
Thank you!
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
It worked. Thank you!
Hello
Can you please sent a token to my basestation once again?
i do not understand why this is needed
// Daniel
Wallndan,
Hi - my Arlo cameras are no longer responding in HomeKit. Can I please get a token reset sent to my base station? Thanks!
JG222,
Also need a token reset please. Thanks
Sandiegoglasguy,
Hi
would it be possible to get a token reset to allow me to use HomeKit which has stopped working. This fixed it last time this happened.
my basestation is a vmb4000r3.
thanks
peter
Mul51,
I'm having same problem. Can you send token reset to my basestaion for homkit.
chlee,
Hi there,
I also need a reset token . I am unable to add my VMB4000r3 on HomeKit.
appreciate the help.
Hi @JamesC ! Could you assist me with the reset pls? Appreciate your help in sorting this!
im also unable to add my base station and cameras to HomeKit.
Regards,
samarth.
Samarth,
Hi, @JamesC I too am unable to connect to HomeKit and was wondering if I could get a token reset as well, thanks!
Revilgaz,
Works perfect now, thank you!
Can I get a token reset as well? Thank you.
cc: @JamesC
asmonitoring,
Thanks for this @JamesC however when I try to add it to my HomeKit, there’s no code available on the box. How are we to add this? Earlier it would be found and then added. Now it asks for a code.
appreciate your help.
Same issue for me on base station 2. Can I get a token reset?
chemguy1973,
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
