  • 31 Replies
  • 12076 Views
  • 3 Likes
morpheus2n2
I found this post and its very similar behavior to what I have.
I have noticed that for the last few months my Cameras show as offline in Google home, I have just spent far to long relinking my account due to HTTP 400 error.
Anyway, MY Arlo app is the latest version, all my Cameras are up to date Firmware wise, and the Google Home app is the latest, my Arlo account is part of the Verisure Package if that helps.
Best answers
  • ShayneS
    I just wanted to let you know the issue has been identified and should resolved with the latest versions 6.6.8 - 6.6.9 which is in a slow rollout phase. Once you receive the update please test again and let me know if the symptom continues.
  • ShayneS
    Just wanted to provide an update. It looks like the cause has been identified and it fix to resolve this is being prepared.
31 REPLIES 31
morpheus2n2
ShayneS
what is the google home version?
morpheus2n2
Not a clue theres no way to check version thay I can see, not to mention that being google home its always upto date as old versions, stop working when they push a auto update out!
ShayneS
Hi @morpheus2n2
Here are a few steps to retrieve the info for the google home version
"Method 1: Through the Play Store
Open the Google Play Store on your Android phone.
Tap your profile icon in the top-right corner.
Tap Manage apps & device → Manage.
Find and tap Google Home from the list of installed apps.
Scroll down to the App info section — it will show the version number.
From phone
Open Settings on your phone.
Go to Apps & notifications (or just Apps, depending on your device).
Find and tap Google Home.
Tap Advanced → App details (sometimes just About) → you’ll see the version number.
From the app
Open the Google Home app.
Tap your profile picture in the top-right.
Tap App settings → scroll down to About — the version number will be listed there."
morpheus2n2
ShayneS
@morpheus2n2 Thank you, I provided this to the appropriate team and I'm waiting to hear back with more info to share.
ShayneS
