- English
- Arlo Forum Discussions
- Partner Integrations
- Arlo Video doorbell chime on Google Home devices
I have seen this question asked and answered many times with a link about setting setting up Arlo devices in Google home. That part is easy but doesn't solve the problem. I have not seen an answer to this question: how do I get Google home devices, such as Nest Mini, to chime or notify when the Arlo doorbell button is pressed? (I have it wired.) Thanks for any help on this.
You will have to connect Your Arlo device to Google Home Via the following link: How do I connect my Arlo cameras to Google Home or Google Assistant?
You should be able to select the device you want to use with Google Home app "doorbell" then when doorbell is pressed it should announce on the Google Hub.
There is also an option to turn voice notifications on/off within the devices settings in the Home app.
AppleTV
31 -
Samsung SmartThings
81 -
Security System
