  • 2 Replies
  • 3076 Views
Retired_Member
Not applicable
Hello,
I see there’s a lot of posts regarding the Apple HomeKit not syncing with a base station VMB5000r6 that was part of the Best Buy ultra 2 kit. Is there something you can reset that would help me? I’m definitely on the same network.
kind regards
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
How do I connect my Arlo device to Apple HomeKit?
https://kb.arlo.com/000063184
BrookeN
Retired_Member
Not applicable
It worked! Thank you!!
