slash128
Luminary
Luminary
I had HomeKit set up but then removed it because I was reorganizing things. Now when I try to add my base station again the app just gets stuck on "Discovering your device. Please wait." I saw this posted elsewhere for a different hub and support sent a token reset request which seemed to resolve the issue for others. Is that what I need here?
613 REPLIES 613
JessicaP
Hi mguida, jaydreams, Paul_T, staring07, Jjayce,
I've sent a token reset request to your Base Station/SmartHub that should resolve the issue. Please reboot your Base Station/SmartHub (remove and reapply power), allow the Base Station/SmartHub to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit
Retired_Member
Not applicable
I'm also stuck on discovering your devices.
Jjayce
no change in behavior still unable to add to HomeKit.
JessicaP
Hi LuisBueno2486,
Hey Jjayce,
I've sent a token request to your Base Station again. If you're still having issues, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
GrantGoldkey
Hi Jessica,
Could you please send a reset to my base station as well?
I am having the same problem as described - Homekit used to work but was removed, and now sticks on "Discovering Devices".
Many thanks!
JessicaP
Hi GrantGoldkey,
Soulfab
I would like to have my token reset for HomeKit setup. It stopped working once I added a new ATV to my network.
Thank you!
Arctype
Homekit and Arlo previously worked and now it seems broken. I deleted the arlo baby cam from HomeKit and then tried to re-enable by going into the device (firmware is updated, already checked) and then within the app towards the button I hit set up and Discovering your device appears.....forever. It does nothing. I restart the device. I let it sit and then start the process over again only to find...nothing! same thing over and over. ugh. Any ideas?
Andyfi
Can you please send a token reset to my Arlo baby camera? I am unable to add it to homekit.
JessicaP
Hi Soulfab and Arctype,
I've sent a token reset request to your Arlo Baby camera that should resolve the issue. Please reboot your Arlo Baby camera (refer to this article to learn how: How do I power cycle my Arlo Baby camera?), allow the camera to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit
Hi Andyfi,
D_Joshi
JessicaP
Hi D_Joshi,
D_Joshi
Hi Jessica - tried doing that but seems its still not working. It says discovering device, please wait… & nothing happens.
JessicaP
Hey D_Joshi,
Andyfi
I’m using the Arlo baby, not a base station. The tome. Reset you sent didn’t work.
Blimmins
jupiterfish
JessicaP
Hi Andyfi,
I've sent a token request to your Arlo Baby camera again. If you're still having issues, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Hey Blimmins and jupiterfish,
Scoike
Hi Jessica,
What is it that you all plan on doing to address this issue.  My Arlo cameras have all dropped out of HomeKit again after 6 months since you last sent a token reset for me. There needs to be some better platform stability because this stuff is very much set it and forget it and there is nothing more frustrating than seeing my cameras disappear when I haven't touched anything and having to go through a forum to get in touch with someone is even worse. Can you please send a token reset to my base station again. I'm hoping that will resolve the issue again.
z0rak
Hi Jessica,
I am also no longer able to get past the "Discovering Your Device" phase for Homekit setup.  Can you please send a token reset request?
JessicaP
Hi z0rak,
thomasc82
Hello, I’m also having the same issue where I am stuck on discovering devices when I try to add my cameras to HomeKit. Can I get a reset token please?
Retired_Member
Not applicable
Hi Jessica,
JessicaP
Hi thomasc82, TheKFCuracao,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Kway13
Hi Jessica. I am having the same problem with no resolution when I called customer service. Please help.
