- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Apple HomeKit stuck at "Discovering your devic...
I had HomeKit set up but then removed it because I was reorganizing things. Now when I try to add my base station again the app just gets stuck on "Discovering your device. Please wait." I saw this posted elsewhere for a different hub and support sent a token reset request which seemed to resolve the issue for others. Is that what I need here?
Hi dvmeeks,
I've sent a token reset request to your Base Station/SmartHub that should resolve the issue. Please reboot your Base Station/SmartHub (remove and reapply power), allow the Base Station/SmartHub to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
I have the exact same issue too.
Please assist.
P.S: I have two base stations. Both are identical. One of them has connected to HomeKit while the other one is stuck at “Discovering..”
Hi chanderr and Jtbillups,
Hi davidhibbard,
Hi Nadine-,
After some time poking around on the community, it seems that I’m having the same issue as many others where I’m getting stuck on the HomeKit setup screen. It says “Discovering your device. Please wait.” and never progresses. The solution seems to be a token reset on the support side. Can I have someone do one of those for me please? Thanks!
I am now having a secondary problem. The cameras say they are not compatible with apples secure video however is says on the product details and apples website that this camera should be compatible. How do I get this to record in apples secure video?
Hi ggsja,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Nadine-,
Arlo does not currently plan to support Apple HomeKit Secure Video, but we will support a range of other features that will enable Arlo cameras to participate in the HomeKit ecosystem.
Hi Jacob4130,
I have reviewed similar topics (Homekit integration fails - "uncertified accessory" error message) but none of the solution worked for me using the VMB5000/Ultra2 setup. Appreciate help/guidance how to get this fixed please as the whole reason why I bought this kit is the fact that it works with my HomeKit setup. When I use the Arlo app, I can get to the Locate the QR code option, scan the provided QR code and then I get "Connecting to Bridge. This may take a few minutes." I have kept it running for nearly 2hrs non-step now ... and it still seems to "connect" to something but no ideas what ... it feels it may be stuck in a continuous loop or is hung. I need help/advice to fix this urgently please!
Hello, I am experiencing the same issue. Can you please send a token reset to my base station?
Hi past1999, stcurry,
I am having the same issue trying to connect with Homekit...
Can you send me a token
Can I get the token reset? Thanks!
Hi Johnyf, espaladin,
Hi Andreabrivio197,
Please make sure your Base Station/SmartHub is online so I can send a token reset request to your Base Station/SmartHub.
could i get a token reset sent to my base station please & thx!!
Hi Starlite,
I would Like to try a reset token to try to resolve my HomeKit issue
I also want to see if it’s possible to have one of my ultra that fails to pair to the base station to actually connect to my vbm5000
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
