Apple HomeKit - Stuck on 'Discovering your device'
  • 16 Replies
  • 2678 Views
  • 7 In Conversation
brampower
Hello,
I am unable to add my Arlo Base Station to Apple HomeKit, it is just stuck on 'Discovering your device'. Would I be able to get a token reset please?
BrookeN
@brampower  and @Nick15  I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
https://kb.arlo.com/000063184
16 REPLIES 16
Nick15
I am having the same problem with my Base Station.  When I go in the Arlo App, Base Station Settings, I have no option to enable HomeKit.
How is this issue solved?
BrookeN
brampower
Thank you for your assistance. Everything is working now!
BrookeN
@brampower you will need to reset the basestation. Please keep in mind that you will need to add the cameras back to the account. After resetting the basestation, please follow the steps to set up without a code. From the link that was provided.
cgmckeever
@BrookeN How could I request a token reset? Thank you
BrookeN
cgmckeever
Thank you @BrookeN
The Arlo base/cameras are not listed in home (settings -> hubs)
unplugged/rebooted arlo basestation
Unplugged/rebooted Apple tv
Arlo App -> router -> info -> homekit -> Devices Found [SPINNER]
Any ideas what my be out of sync? Cameras we connected up until a week ago
thank you
BrookeN
If you can not see the cameras you may need to reset the basestation. Please keep in mind if the basestation is reset you will need to add back all the cameras.
cgmckeever
Thanks -- there is no workaround for this issue without a reset?
BrookeN
If you already did the reboot and try it that way, then no that is the next step.
Morko
May I have a token sent to mine as well please, I’m having the same stuck on discovering and have tried every other suggestion.
thanks
BrookeN
@Morko I seen your message and that you were able to resolve this. I will close this out.
Morko
Thank you, and as I DM’ed you the reason, for others benefit was I have a router and a seperate wifi 7 router, the Arlo was plugged into the first router but the Apple home was running from the wifi router, so you must have the Apple and Arlo plugged into the same wifi router.
Yes.   The wifi 7 router has its own NAT firewall, which blocks Apple Home.
The other option would be to set up the wifi 7 router as an access point.
Glasshalffull
Hi @BrookeN i also have this issue with one of my base stations. Could you also reset my token?
BrookeN
@Glasshalffull I for sure can. Do you want it reset on both your basestations?
