- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Apple HomeKit - Stuck on 'Discovering your dev...
Hello,
I am unable to add my Arlo Base Station to Apple HomeKit, it is just stuck on 'Discovering your device'. Would I be able to get a token reset please?
@brampower and @Nick15 I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
I am having the same problem with my Base Station. When I go in the Arlo App, Base Station Settings, I have no option to enable HomeKit.
How is this issue solved?
Thank you for your assistance. Everything is working now!
@brampower you will need to reset the basestation. Please keep in mind that you will need to add the cameras back to the account. After resetting the basestation, please follow the steps to set up without a code. From the link that was provided.
@BrookeN How could I request a token reset? Thank you
Thank you @BrookeN
The Arlo base/cameras are not listed in home (settings -> hubs)
unplugged/rebooted arlo basestation
Unplugged/rebooted Apple tv
Arlo App -> router -> info -> homekit -> Devices Found [SPINNER]
Any ideas what my be out of sync? Cameras we connected up until a week ago
thank you
If you can not see the cameras you may need to reset the basestation. Please keep in mind if the basestation is reset you will need to add back all the cameras.
Thanks -- there is no workaround for this issue without a reset?
If you already did the reboot and try it that way, then no that is the next step.
May I have a token sent to mine as well please, I’m having the same stuck on discovering and have tried every other suggestion.
thanks
@Morko I seen your message and that you were able to resolve this. I will close this out.
Thank you, and as I DM’ed you the reason, for others benefit was I have a router and a seperate wifi 7 router, the Arlo was plugged into the first router but the Apple home was running from the wifi router, so you must have the Apple and Arlo plugged into the same wifi router.
Yes. The wifi 7 router has its own NAT firewall, which blocks Apple Home.
The other option would be to set up the wifi 7 router as an access point.
Hi @BrookeN i also have this issue with one of my base stations. Could you also reset my token?
@Glasshalffull I for sure can. Do you want it reset on both your basestations?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
