  • 12 Replies
  • 4747 Views
Truth2121
I am having trouble adding Arlo to Home Kit.  I don't see anywhere on the Arlo app regarding Home Kit.image.jpg
12 REPLIES 12
If you see "Library" in your app menu, then read through this:
If you instead see "Feed" and "Dashboard", then read through this:
You might need a token reset to get this working.  The mods can do this for you, alternatively you can reach out to Arlo support.
Either way, while Arlo supports some homekit features, they do NOT support home secure video.
ShayneS
I reset your Homekit token, Can you reboot your base station and remove and reinstall the Arlo app?
Truth2121
ShayneS
Can you reboot the base and reinstall the app again.
Truth2121
I did try to reboot and reinstall the app.  Same message as i posted earler.
ShayneS
Looking at your screenshot closer, can you make sure you are on the same home wifi network as the Smart Hub and try again.
Truth2121
How do I see what network the base station is on?
It's connected to your router's ethernet.
@ShayneS wants you to make sure your phone is connected to your home wifi.  Also, if you use a VPN on your phone,  then turn it off while you are adding to homekit.
Truth2121
Thank, yes the base station is attached to the ethernet (5.0) which is the same network I am using on my phone.
ShayneS
Do you see the wifi bars at the top right of the mobile device? In the screenshot for your post regarding "stuck on discovering" it shows 5G for mobile data. You need to be connected to the same wifi network as the base station.
Truth2121
Yes,  I am on the same wifi.
ShayneS
Thanks, can you try factory resetting your base station and try adding to HomeKit again.
You can find more info here: https://kb.arlo.com/1057976/How-can-I-factory-reset-my-Arlo-SmartHub-or-Base-Station
