I’m experiencing a HomeKit refresh issue on AVD1001 with the OS 16.5-.6 series. The doorbell does not refresh automatically like the cameras. Any observed this issue?
Thank you for the update, glad to hear it is working. I will check in to see if there was an update released.
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
I've rebooted the hub and VDB. This appears to have stopped working around iOS/iPAD os 16.5.1.
If you click the "Security" tab does it initiate a refresh when you go back to the "Home" > Cameras view?
No, it does not.
Okay, and just to make sure I'm understanding this correctly, when you open the HomeKit app on the Home/Home Tab page with Home/Automation/Discover at the bottom, the Cameras section does not update the thumbnails and show the live stream snapshots with the seconds updating 1, 2, 3 etc..?
When you go in to the Security tab under the cameras list, do the cameras auto live stream with the seconds accumulating?
Non-VDB cameras work correctly (e.g. refresh every 10-15 seconds). Recently, my VDB never refreshes automatically only on-demand.
Okay, thanks. I will look in to this and provide more feedback as soon as possible.
Any update on this topic?
I'm waiting for feedback from the team. I'll be sure to update you as soon as I have more info.
@Isacksenfamily Are you able to send me a screen recording of the doorbell not refreshing?
You can send it to [email protected] Subject Shayne/12007550
sent 16-aug, update?
I provided this to the team, They started investigating last week. I'll update you when I receive more info.
Can you re-engage engineering support. I received a message on 23-Aug; however, no more since.
The development team is still currently investigating this.
Issue appears resolved. VDB refreshes on HomeKit. Was a patch deployed?
Perfect, thanks. Assuming yes.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
