Unable to add Arlo base to Homekit
  • 4 Replies
  • 2251 Views
Daveblademan
I had to reset my entire HomeKit environment recently and delete my HomeKit/Arlo connection. I can no longer re-add my Arlo base station to HomeKit (just sits spinning on the ‘Devices Found..’ stage  - I’ve seen others refer to a ‘token reset’ being needed ?
Can you help pls ?
ShayneS
Thank you
quanm
Hello, I also need a token reset for my Arlo/Homekit pairing, please assist!
BrookeN
@quanm and @Daveblademan your token has been reset. You will need to reboot the smarthub/base station.
Daveblademan
You rock Shayne - thanks
