  • 3319 Views
cfcarey
Two options to click on when setting up a schedule - Armed and All Motion On. What is the difference?
Sounds like you had the system before the new year update. Theoretically they're identical but real life has shown custom modes, such as All Motion On, may have issues. I'd delete that one and just use Armed.
khm1208
How do I delete the ALL MOTION ON and use the ARMED option ? I did buy this after the New Year update.
You should be able to delete the All Motion On mode by editing the mode and click on the Delete button at the bottom.  If that fails for some reason, try using the app or browser, whichever you're currently not using.
