  • 7 Replies
  • 4601 Views
  • 2 Likes
mqrc
I only get a motion detection alert as an e-mail. how do I get them on my phone as a sms?
You can get an SMS mesg as an alert by using your phone number as an email adress. Some systems work better than other and clip out extra HTML, some don't.... but its still an easy quick method for me to get an alert. ( BTW, no spaces/dashes, just all ten digits )
Like in the following formats;
AT&T: [email protected]
Cingular: [email protected]
Metro PCS: [email protected]
Nextel: [email protected]
Powertel: [email protected]
Sprint: [email protected]
SunCom: [email protected]
T-Mobile: [email protected]
US Cellular: [email protected]
Verizon: [email protected]
Virgin Mobile: [email protected]
7 REPLIES 7
Hula_Rock
Prodigy Prodigy
Prodigy
For ATT:
[email protected] stopped working.  you have to use this format:
[email protected].
good to know... mms use to be for pics.
do u know if it does pass or clip the extra html?
Hula_Rock
Prodigy Prodigy
Prodigy
@TomMac
its "suppose" to since it is routed via @mms.att.net but I have only seen it work once correctly since I bought this system.  Looks like the HTML format has an error in the line code throwing it off.  I have tested it and sent a picture to my phone with HTML text and it works fine.  Maybe something on the Netgear end.
Not fluent in HTML, hahah, UNIX on the other hand.......
mqrc
thank you, now it works!!
angstwad
Also, there's a service that does this already and sends image alerts via text/SMS: https://textmeplz.com/
mqrc
great, many thanks
