Re: Two Phones, One Geofencing Problem
Highlighted
We're having the same issue..
My husband has the 'friend' account and it used to work perfectly, that when one of us was within/out of the geofencing zone it would disarm/arm, but now for some reason has stopped working. It won't arm/disarm whenever he is out of or in the geo-zone, but instead just receives a pop up notifying him that he's in or out of the zone... not helpful. We have uninstalled & reinstalled the apps from both of our phones and checked that all settings are correct but still not working. Help?!
Model: VMB3000 | Arlo Base Station
Highlighted
Exact same issue and symptoms as Jamokebob.
Highlighted
I have the same issue.  I added a shared account to geofecing.  But it seems like it only works on the primary (admin) account.  Whenever my phone (with admin account) left the zone, it arms the system even the other shared account still in the zone.  Very disappointed.
Highlighted
I experinced the same problem, but when I disable the shader account from geofencing and save the setting. Then re-enable it, the system disarms as designed.
Don't know if the correct operation persists, but at least this is a temporary fix.
Model: VMC3030 | Arlo Wire-Free Camera
Highlighted
So far, so good... Smiley Happy
Still perfect operation after 1 day and several events.
So this seems to correct the issue.
Highlighted
Anssi thank you. This solved my issue as well.
