  • 4 Replies
  • 2242 Views
Pegger07
I am trying to switch my alerts to text messages instead of email, but when I get a confirmation text, thEre is no link to confirm (it appears to be code, but no link to click on)
Not sure what you're seeing.  Arlo supports two types of notifications - email and app.  Texts are not possible although TomMac has a method for sending email alerts to text. Are you trying to use his method to get texts?
J is right ...Arlo only offically supports email or pushes ( android/ios )
In order to get TEXT or sms on my phone, I used the format verizon gives to convert email to text ( each service provider is diff , There is a list on here )
exp;  'phonenumber'@vtext.com for email converts to sms
formats as follow;
AT&T: [email protected]
Cingular: [email protected]
Metro PCS: [email protected]
Nextel: [email protected]
Powertel: [email protected]
Sprint: [email protected]
SunCom: [email protected]
T-Mobile: [email protected]
US Cellular: [email protected]
Verizon: [email protected]
Virgin Mobile: [email protected]
Pegger07
Thank you both, I am using TMs method and did get a text (similar to an email) where I had to confirm my email to get alerts, it looks like:
Subj: Your Arlo Change-Of-Address Is Official! : Your Arlo Change-Of-Address Is Official! body background:#EEEE; padding:45pz 5%; margin:0; position:relative; display:block; font-family:Arial, Tahoma, sans-serif; cursor:default; line-height:normal; a,img outline:none; border:none;
Any thoughts?
Yes.... it has been seen that some carriers DO NOT filter out all the html that comes thru from Arlo.
I get some now and then but it's still easier to read the quick sms over an email on my smart phone ( due to pop -up )
If needed then i sign into the app.
