Should I Start Over?
  • 1 Reply
  • 1878 Views
Z00KA
I have 3 cameras with Basic Service.  I have my outside cameras set for motion on from 9:55pm until 4:55am on the following morning, one of my outside cameras records all movement all the time.
Should I delete all my schedules and modes andd start over?
I just want it to record movement on the times (see above) I specify in Schedules.
Thanks in advance for all responses.
Joe
delete the schedule ,then check the MODES but don't delete.
To CHECK the all motion on mode, manually turn ALL MOTION ON  and then go to live camera view screen... the "running man" on top of each camera should be GREEN ( means on ).
If this is ok , test ALL OFF and now the running men should be GRAY ( OFF )
Now if both work, go back to shedule and redo for the time wanted.
