  • 1 Reply
  • 1913 Views
anjaneyat
My camera has a tree in it range and every time the leaves moves (slight breeze or bird) I get a motion alert. Is there a way to eliminate such minor movements?
Thanks.
Showguy
Virtuoso
Virtuoso
You can try to play with the sensitivity settings until you get better results. Keep in mind that minimizing the sensitivity may help with the blowing branches but wild life will probably not be filtered out. The system is designed to detect that type of movement. Also keep in mind that to much sensitivity reduction may eleminate detection of motion you want detected. Proper placement of cameras in this type of system is crucial for getting the results you want.
