No motion detection on one camera
  • 1 Reply
  • 1954 Views
Amcnally
3 cameras can be activated with motion. The 4th does only live feed. Not sure how to restore the one camera. Under cameras it shows all 4 however when I go to Rules only 3 show up.? I've tried to resend it but still only get real feed. Any suggestions on how to get the camera to re activate the motion detection feature?
Showguy
Virtuoso
Virtuoso
Try to create a "new" rule for that camera.
Settings / Rules/ click the (+) button to create new rule. Chose the camera for the rule and what it should do. Click save.
After the the rule is created you have to add the new rule to the " mode" you are using. To do this:
settings/ mode/ edit. Look for the new rule, tap on it so it turns green. Click save.
Good luck.
