See how much storage left
  • 6 Replies
  • 4194 Views
  • 2 Likes
  • 5 In Conversation
Josepf
Hi, is there a way to check in the app or via browser how much storage space is left. I have a basic plan.
Thank you.
There is no worry about your limit, as it's a non-factor, be concerned with the 7 days... on the 8th day, day #1 is deleted.
if you have naything you want to save, d/l it.
6 REPLIES 6
Josepf
Cbird
Doesn't it only save the last 1gb of video?
Cbird,
Library content is saved to the cloud for 7 days. After 7 days content is automatically deleted unless you have a subscription plan allowing it to remain for a longer period (30 days for Premier, 60 days for Elite).
jhd14
Hi JamesC:
I think a source of confusion is this page:
http://www.arlo.com/en-us/products/subscription-plans.aspx
Currently it reads:
Basic
  • 7 Days of Cloud Recordings
    (Up to 1GB Cloud storage)
  • Up to 5 cameras
  • Limited Support for 3 Months
FREE
Can this page be updated so that new users are not confused about the old 1GB limit?
Thanks.
I know Netgear has been trying to update the info ....
It does refer back to the SW pre Jan 2016 when there was a big change (total SW revamp).
