  • 6 Replies
  • 3314 Views
Bluey59
Since IOS 10 update, neither my Iphone 6s nor Ipad will retain password and auto log in. I am not logging out after using the app.
No problem with my Mac. It is a major problem given my usage pattern, and was working fine until IOS10.
Help!
Bluey59
After trying many paths I decided to remove the apps from the IOS devices and reload. This has worked and both now remember the username and password.
Thanks for your assistance.
Blueysmith59
6 REPLIES 6
Recently some one else had iOS 10 problems...
invole a reboot of the phone.
cant help much more as old timers are still running 9.3.5.     🙂
Bluey59
Thanks for the reply TomMac, but no joy.
Put in a trouble report ; Support at top of page, next page contact support.
This will put the iOS 10 into the gene pool and maybe a better answer down the road.
Bluey59,
Thank you for the report, I agree with TomMac that you should consider opening a support ticket for this issue. I will also escalate this topic for further investigation.
Thank you,
Bluey59
Thanks folks I will do that.
Bluey59
Bluey59
Blueysmith59
