  • 2197 Views
Giouser
The idea is that if the garage camera detects motion it has the option to turn on other cameras simultaneously.
Already available by creating custom modes with nested rules.
Cam1 detects, Cam1 records
Cam1 detects, Cam2 records
lauraheck
You mention 'cam1 detects, cam1 records'
When editing my rule, I'm unable to select cam1 records, when cam1 is selcted to detect montion.
If the following, cam1 detects motion.
Then do the following -> ONLY cam2, cam3 cam4 are my available choices. I can't select cam1.
Any thoughts on what I'm doing wrong?
Interesting - it should show all cameras to select on both which camera detects as well as which to record on - it does here.  I'm not sure what to tell you other than maybe reset the whole system by removing everything from Settings, My Devices and start fresh or contact support and open a case.
