  • 2 Replies
  • 2196 Views
dkh
While going through the motions of learning how to adjust my cameras motion sensitivity and record time I have added "rules and created activity zones that conflict with each other.I would like to know how to get back to the factory default settings so I can start over with a clean slate.
Dinerve
Make sure you don't change the Armed mode since it's a default and you can always refer to it as a reference.  Always create your own custom modes/rules - that way, you can either edit them for what you want or simply delete the mode and start over.
The default settings for each camera in the Armed mode are:
Sensitivity - 80
Recording time - 10 seconds
Notifications - email and push both enabled
