  • 13 Replies
  • 4575 Views
  • 8 In Conversation
gilbo2
Luminary
Luminary
For the last couple of days when starting the iOS app on either my iPad or iPhone the "Mode" button does not always appear. I have to keep fully closing the app and restarting it until it shows again.
The Android and Web versions are working fine.
Anyone else noticed this?
PS I am using the latest App updates.
gilbo2
Luminary
Luminary
JamesC wrote:
An update for the iOS Arlo mobile app was recently released addressing various minor bugs. After installing the latest update for the mobile app are you still experiencing this issue?
Release Notes - iOS App 2.1.1 - 16th June 2016
This iOS update does seem to have fixed the problem on my devices, thanks.
13 REPLIES 13
Have not seen this occur on the Ipad v3 running ios 9.3  ( just did the upgrade to 9.3.2 (?) this morning so will see if any change.
gilbo2,
What model/iOS versions are your iOS devices?
gilbo2
Luminary
Luminary
Both my iPad2 and IPhone6 are on iOS 8.1.2
gilbo2,
This could be due to the outdated version of iOS. Consider updating your devices to the latest version of iOS and try again.
Lard313
I noticed the same thing. My iOS is fully up to date.
Pavlova
I have an iPhone 6s with iOS 9.3.2 (i.e. latest ios). The Mode button is NEVER present when I open the Arlo app. Only Camera, Library and Settings are present when the App opens. However, the Mode button typically appears about 2 seconds later, but it sometimes takes longer for Mode to appear. I don't have to close/re-open the App for it to appear.
I see the same behavior described by Pavlova. After a second or two the Mode button will be present at the bottom of the app screen.
gilbo2,
Are you still experiencing this issue after updating your iOS version?
gilbo2
Luminary
Luminary
Sorry, I am not able to update my iOS so unable to advise. Problem is very random though and seems less likely when connecting via my mobile network rather that WiFi.
fobbson
same problem for me! (iOS 😎 But worked perfectly 2months ago
gilbo2
Luminary
Luminary
apeace
there is no mode selection icon on my iphone 6.  I am the added device to our account and I can not change the mode from my phone.  the update to the app has not resolved this issue.
Perhaps you don't have admin access set in the main account under Grant Access?
