VMS3230-100NAS need help arming both cameras
  • 1 Reply
  • 1266 Views
Shon
Hello, we need assistance setting the motion detector on both camera at the same time if possible.  It is only allowing us to set one or the other please advise.
Thank you in advance
tinokremer
What exactly are you trying to accomplish?
If you want to arm your camera's at the same time, use the "Armed" mode or create a new mode if you like. In the mode you setup which cameras are "armed" (motion detector is used to detect motion and then record / send notifications), as well as the sensitivity. You just have to select the mode you like and all cameras are armed or disarmed at the same time.
If you want to do something else please provide more information on your setup and what you are trying to do.
tinokremer
